模具术语
330 浏览
模具术语中英文对照
材料类 海绵宝宝 2017-03-08 18:03 发表了文章
上模:Upper Die
上模座:Upper die holder
下模:Lower die
下模座:Lower die bottom
环模:Holder die
压料板:Pad
安全护板:Safety Guard
耐磨板:Wearplate
吊耳:Hook
插入式吊耳:Insert hook
搬运固定板:Fix in Plates
防呆装置:Fool Proofing
快速定位:Quick Clamp
安全侧销:Retainer pin sets(Safety)
保管垫块:Blocks
平衡垫块:Balancer block
停止垫块:Stoper block
氮气缸:NiirogenSpring
到底记号:Check Buttons
镶块:Insert Block
素材定位器:Nest Guide
进退料支架:SKID Brackets
脱料板:Stripper die
顶料块:lift block
零件详细:Parts detail
检具:Checking Fixture
气缸:Cylinder
接头:Adapter(Augmture)
快速接头:Quick Nipple
三向接头:Three-Way Connector
万向接头:Universal-Joint adapter
L型快速接头:L Joint
T型快速接头:T Joint
阀:Valve
调速阀:Covernor Valve
方向调节阀:Directional Control Valve
定位销:Location Pin
开口销:Split Pin
带头销:Pin with head
固定销:Doweel Pin
夹:Clamp
管:Pipe
连接管:Connector
排气孔:Air Vent
轴:Shaft
连杆轴:Link shaft
下模钢块:Lower Steel
行程定位:Stroke end block
废料刀:Scrap cutter
废料盒:Scrap Box
定位键:locating key
凸轮组件:Cam Unit
凸轮滑动座:Cam Slide
凸轮驱动座:Cam driver
凸轮侧滑块:Cam side slide
切刀块:Cutter Nlock
分块:Sectional Block
导柱:Guide Post
导套:Guide bush
导柱组:Guide Post Set
缓冲垫块:Cushion Plate
挡板(块):Baffle
垫块:Plate
垫圈:Washer
焊接:Welding
树脂:Resin
消音器:Muffle
螺帽:Nut
有槽螺帽:Slotted Nut
销规:Guage
承盘:Retainer
柱塞:Plunger
端子箱:Cable connecting Box
集头座:Connector Support
内六角螺栓:SHC Screw
内螺纹圆柱销:DOWEL PIN
吊挂:Retainer Bolt
弹簧导销:Spring Guide retainers
工法图:Die layout
上模面:Upper die of plan view
下模面:Lower die of plan view
断面:Section
冲头:Punch
固定块:Fix Plate
作用套管:Spool Retainer
滚轮:Rubber roller
衬套:Bushing
冲头固定座:Retainer
盖板:Safety Guard
托架:Bracket
曲柄:Crank
下模:Lower die
环模:Holder die
压料板:Pad
安全护板:Safety Guard
耐磨板:Wearplate
吊耳:Hook
插入式吊耳:Insert hook
搬运固定板:Fix in Plates
防呆装置:Fool Proofing
快速定位:Quick Clamp
保管垫块:Blocks
平衡垫块:Balancer block
停止垫块:Stoper block
氮气缸:NiirogenSpring
到底记号:Check Buttons
镶块:Insert Block
素材定位器:Nest Guide
进退料支架:SKID Brackets
脱料板:Stripper die
顶料块:lift block
零件详细:Parts detail
检具:Checking Fixture
气缸:Cylinder
快速接头:Quick Nipple
L型快速接头:L Joint
T型快速接头:T Joint
阀:Valve
调速阀:Covernor Valve
定位销:Location Pin
开口销:Split Pin
带头销:Pin with head
固定销:Doweel Pin
夹:Clamp
管:Pipe
连接管:Connector
排气孔:Air Vent
轴:Shaft
连杆轴:Link shaft
下模钢块:Lower Steel
废料刀:Scrap cutter
废料盒:Scrap Box
定位键:locating key
凸轮组件:Cam Unit
凸轮滑动座:Cam Slide
凸轮驱动座:Cam driver
切刀块:Cutter Nlock
分块:Sectional Block
导柱:Guide Post
导套:Guide bush
导柱组:Guide Post Set
缓冲垫块:Cushion Plate
挡板(块):Baffle
垫块:Plate
垫圈:Washer
焊接:Welding
树脂:Resin
消音器:Muffle
螺帽:Nut
有槽螺帽:Slotted Nut
销规:Guage
承盘:Retainer
柱塞:Plunger
内六角螺栓:SHC Screw
内螺纹圆柱销:DOWEL PIN
吊挂:Retainer Bolt
工法图:Die layout
断面:Section
冲头:Punch
固定块:Fix Plate
作用套管:Spool Retainer
滚轮:Rubber roller
衬套:Bushing
冲头固定座:Retainer
盖板:Safety Guard
托架:Bracket
曲柄:Crank
上模:Upper Die
下模:Lower die
环模:Holder die
压料板:Pad
安全护板:Safety Guard
耐磨板:Wearplate
吊耳:Hook
插入式吊耳:Insert hook
搬运固定板:Fix in Plates
防呆装置:Fool Proofing
快速定位:Quick Clamp
保管垫块:Blocks
平衡垫块:Balancer block
停止垫块:Stoper block
氮气缸:NiirogenSpring
到底记号:Check Buttons
镶块:Insert Block
素材定位器:Nest Guide
进退料支架:SKID Brackets
脱料板:Stripper die
顶料块:lift block
零件详细:Parts detail
检具:Checking Fixture
气缸:Cylinder
快速接头:Quick Nipple
L型快速接头:L Joint
T型快速接头:T Joint
阀:Valve
调速阀:Covernor Valve
定位销:Location Pin
开口销:Split Pin
带头销:Pin with head
固定销:Doweel Pin
夹:Clamp
管:Pipe
连接管:Connector
排气孔:Air Vent
轴:Shaft
连杆轴:Link shaft
下模钢块:Lower Steel
废料刀:Scrap cutter
废料盒:Scrap Box
定位键:locating key
凸轮组件:Cam Unit
凸轮滑动座:Cam Slide
凸轮驱动座:Cam driver
切刀块:Cutter Nlock
分块:Sectional Block
导柱:Guide Post
导套:Guide bush
导柱组:Guide Post Set
缓冲垫块:Cushion Plate
挡板(块):Baffle
垫块:Plate
垫圈:Washer
焊接:Welding
树脂:Resin
消音器:Muffle
螺帽:Nut
有槽螺帽:Slotted Nut
销规:Guage
承盘:Retainer
柱塞:Plunger
内六角螺栓:SHC Screw
内螺纹圆柱销:DOWEL PIN
吊挂:Retainer Bolt
工法图:Die layout
断面:Section
冲头:Punch
固定块:Fix Plate
作用套管:Spool Retainer
滚轮:Rubber roller
衬套:Bushing
冲头固定座:Retainer
盖板:Safety Guard
托架:Bracket
曲柄:Crank
330 浏览
模具术语中英文对照
上模:Upper Die
下模:Lower die
环模:Holder die
压料板:Pad
安全护板:Safety Guard
耐磨板:Wearplate
吊耳:Hook
插入式吊耳:Insert hook
搬运固定板:Fix in Plates
防呆装置:Fool Proofing
快速定位:Quick Clamp
保管垫块:Blocks
平衡垫块:Balancer block
停止垫块:Stoper block
氮气缸:NiirogenSpring
到底记号:Check Buttons
镶块:Insert Block
素材定位器:Nest Guide
进退料支架:SKID Brackets
脱料板:Stripper die
顶料块:lift block
零件详细:Parts detail
检具:Checking Fixture
气缸:Cylinder
快速接头:Quick Nipple
L型快速接头:L Joint
T型快速接头:T Joint
阀:Valve
调速阀:Covernor Valve
定位销:Location Pin
开口销:Split Pin
带头销:Pin with head
固定销:Doweel Pin
夹:Clamp
管:Pipe
连接管:Connector
排气孔:Air Vent
轴:Shaft
连杆轴:Link shaft
下模钢块:Lower Steel
废料刀:Scrap cutter
废料盒:Scrap Box
定位键:locating key
凸轮组件:Cam Unit
凸轮滑动座:Cam Slide
凸轮驱动座:Cam driver
切刀块:Cutter Nlock
分块:Sectional Block
导柱:Guide Post
导套:Guide bush
导柱组:Guide Post Set
缓冲垫块:Cushion Plate
挡板(块):Baffle
垫块:Plate
垫圈:Washer
焊接:Welding
树脂:Resin
消音器:Muffle
螺帽:Nut
有槽螺帽:Slotted Nut
销规:Guage
承盘:Retainer
柱塞:Plunger
内六角螺栓:SHC Screw
内螺纹圆柱销:DOWEL PIN
吊挂:Retainer Bolt
工法图:Die layout
断面:Section
冲头:Punch
固定块:Fix Plate
作用套管:Spool Retainer
滚轮:Rubber roller
衬套:Bushing
冲头固定座:Retainer
盖板:Safety Guard
托架:Bracket
曲柄:Crank
下模:Lower die
环模:Holder die
压料板:Pad
安全护板:Safety Guard
耐磨板:Wearplate
吊耳:Hook
插入式吊耳:Insert hook
搬运固定板:Fix in Plates
防呆装置:Fool Proofing
快速定位:Quick Clamp
保管垫块:Blocks
平衡垫块:Balancer block
停止垫块:Stoper block
氮气缸:NiirogenSpring
到底记号:Check Buttons
镶块:Insert Block
素材定位器:Nest Guide
进退料支架:SKID Brackets
脱料板:Stripper die
顶料块:lift block
零件详细:Parts detail
检具:Checking Fixture
气缸:Cylinder
快速接头:Quick Nipple
L型快速接头:L Joint
T型快速接头:T Joint
阀:Valve
调速阀:Covernor Valve
定位销:Location Pin
开口销:Split Pin
带头销:Pin with head
固定销:Doweel Pin
夹:Clamp
管:Pipe
连接管:Connector
排气孔:Air Vent
轴:Shaft
连杆轴:Link shaft
下模钢块:Lower Steel
废料刀:Scrap cutter
废料盒:Scrap Box
定位键:locating key
凸轮组件:Cam Unit
凸轮滑动座:Cam Slide
凸轮驱动座:Cam driver
切刀块:Cutter Nlock
分块:Sectional Block
导柱:Guide Post
导套:Guide bush
导柱组:Guide Post Set
缓冲垫块:Cushion Plate
挡板(块):Baffle
垫块:Plate
垫圈:Washer
焊接:Welding
树脂:Resin
消音器:Muffle
螺帽:Nut
有槽螺帽:Slotted Nut
销规:Guage
承盘:Retainer
柱塞:Plunger
内六角螺栓:SHC Screw
内螺纹圆柱销:DOWEL PIN
吊挂:Retainer Bolt
工法图:Die layout
断面:Section
冲头:Punch
固定块:Fix Plate
作用套管:Spool Retainer
滚轮:Rubber roller
衬套:Bushing
冲头固定座:Retainer
盖板:Safety Guard
托架:Bracket
曲柄:Crank
上模:Upper Die
下模:Lower die
环模:Holder die
压料板:Pad
安全护板:Safety Guard
耐磨板:Wearplate
吊耳:Hook
插入式吊耳:Insert hook
搬运固定板:Fix in Plates
防呆装置:Fool Proofing
快速定位:Quick Clamp
保管垫块:Blocks
平衡垫块:Balancer block
停止垫块:Stoper block
氮气缸:NiirogenSpring
到底记号:Check Buttons
镶块:Insert Block
素材定位器:Nest Guide
进退料支架:SKID Brackets
脱料板:Stripper die
顶料块:lift block
零件详细:Parts detail
检具:Checking Fixture
气缸:Cylinder
快速接头:Quick Nipple
L型快速接头:L Joint
T型快速接头:T Joint
阀:Valve
调速阀:Covernor Valve
定位销:Location Pin
开口销:Split Pin
带头销:Pin with head
固定销:Doweel Pin
夹:Clamp
管:Pipe
连接管:Connector
排气孔:Air Vent
轴:Shaft
连杆轴:Link shaft
下模钢块:Lower Steel
废料刀:Scrap cutter
废料盒:Scrap Box
定位键:locating key
凸轮组件:Cam Unit
凸轮滑动座:Cam Slide
凸轮驱动座:Cam driver
切刀块:Cutter Nlock
分块:Sectional Block
导柱:Guide Post
导套:Guide bush
导柱组:Guide Post Set
缓冲垫块:Cushion Plate
挡板(块):Baffle
垫块:Plate
垫圈:Washer
焊接:Welding
树脂:Resin
消音器:Muffle
螺帽:Nut
有槽螺帽:Slotted Nut
销规:Guage
承盘:Retainer
柱塞:Plunger
内六角螺栓:SHC Screw
内螺纹圆柱销:DOWEL PIN
吊挂:Retainer Bolt
工法图:Die layout
断面:Section
冲头:Punch
固定块:Fix Plate
作用套管:Spool Retainer
滚轮:Rubber roller
衬套:Bushing
冲头固定座:Retainer
盖板:Safety Guard
托架:Bracket
曲柄:Crank
